Adds or deletes the physical port(s) to or from the end-to-end-transparent clock.
add |
Add ports. |
delete |
Delete ports. |
ports |
Physical ports. |
port_list |
List of ports to be added or deleted. |
one-step |
One step operation. |
N/A.
Use this command to add or delete the physical port(s) to, or from, the end-to-end-transparent clock. The fiber only 1G ports, 10G ports, and stack ports cannot be added to the End-to-End transparent clock.
The following example configures end-to-end transparent clock on the front panel ports:
# configure network-clock ptp end-to-end-transparent add ports 1-4 one-step
The following example deletes the front panel ports from the end-to-end transparent clock:
# configure network-clock ptp end-to-end-transparent delete ports 2-4
This command was first available in ExtremeXOS 15.1.
This command is available on the ExtremeSwitching 5420, 5520 and 5720 platforms.
PTP commands can be used only with the Premier license pack.
